[GRASS-dev] Re: [GRASS GIS] #536: memory corruption
trac at osgeo.org
Sat Mar 28 12:48:05 EDT 2009
Reporter: martinl | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords:
Platform: Linux | Cpu: x86-32
Comment (by martinl):
Replying to [comment:12 mmetz]:
> Replying to [comment:11 martinl]:
> > I was too quick - memory corrupted in v.info.
> The earlier gdb didn't tell me a lot. Can you please run v.info with
debug=2 or 3? At least I can work better with that. I'm willing to help,
but I can't reproduce the problem and need more information.
Here it is:
D1/3: field = 1 name = (null), table = elev_ned10m_cont10m, key = cat,
database = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, driver = dbf
D1/3: Dblinks read
| Layer: elev_ned10m_cont10m
| Mapset: PERMANENT
| Database: /home/martin/grassdata
| Title: South-West Wake 10m elevation contours from 10m NED
| Map scale: 1:1
| Map format: native
| Name of creator: helena
| Organization: NC OneMap
| Source date: Tue Nov 7 20:59:46 2006
| Type of Map: vector (level: 2)
| Number of points: 0 Number of areas: 0
| Number of lines: 1008 Number of islands: 0
| Number of boundaries: 0 Number of faces: 0
| Number of centroids: 0 Number of kernels: 0
| Map is 3D: Yes
| Number of dblinks: 1
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 99
D3/3: region item: zone: 0
D3/3: region item: north: 228495
D3/3: region item: south: 215005
D3/3: region item: east: 644995
D3/3: region item: west: 630005
D3/3: region item: cols: 1499
D3/3: region item: rows: 1349
D3/3: region item: e-w resol: 10
D3/3: region item: n-s resol: 10
D3/3: region item: top: 150
D3/3: region item: bottom: 60
D3/3: region item: cols3: 1499
D3/3: region item: rows3: 1349
D3/3: region item: depths: 90
D3/3: region item: e-w resol3: 10
D3/3: region item: n-s resol3: 10
D3/3: region item: t-b resol: 1
| Projection: Lambert Conformal Conic
| N: 228495 S: 215005
| E: 644995 W: 630005
| B: 60 T: 150
D1/3: Vect_get_thresh(): thresh = 0.000000
| Digitization threshold: 0
| Comments:
Segmentation fault
Debugging v.info in Emacs
* In Vect_open_old_head() -> OK
(gdb) p Map->head.line_3
$1 = 0x823c700 ""
* When I leave the function -> memory corrupted
main (argc=2, argv=0xbfac2e54) at main.c:110
$2 = 0x7b1ea71 <Address 0x7b1ea71 out of bounds>
Strange, I have no idea where is problem :-(
Thanks for your help.
Ticket URL: <http://trac.osgeo.org/grass/ticket/536#comment:13>
