[GRASS-dev] Instructions for devel versions added to
CompileOnWindows
Colin Nielsen
colin.nielsen at gmail.com
Sun Mar 29 11:09:41 EDT 2009
I've just finished adding instructions to the Wiki page for compiling
grass-6.5.svn (develbranch_6) and grass-7.0.svn (trunk). Please test.
> Colin, addictionally I suggest you include the format of path as unix
> on some steps, because it facilitate the copy and past (just to save
> time of those the decide to handle the things on MSYS).
> 3. Copy c:\osgeo4w\apps\msys\etc\fstab.sample to
> c:\osgeo4w\apps\msys\etc\fstab (without .sample)
> or
> cp /c/OSGeo4W\apps\msys\etc\fstab.sample /c/OSGeo4W\apps\msys\etc\fstab
> 4. Open c:\osgeo4w\apps\msys\etc\fstab
> or /c/OSGeo4W/apps/msys/etc/fstab
> 3. Open c:\osgeo4w\usr\src\grass64\mswindows\osgeo4w\package.sh and at line
> 12: Change:
> or /c/OSGeo4W/usr\src/\grass64/mswindows/osgeo4w/package.sh
I agree we could probably change step 3 to your suggestion, but I left
those lines in windows format because:
1) Windows users are more familiar with using windows explorer for
file management, and
2) For the other lines just typing /c/osgeo4w/apps/msys/etc/fstab will
not open the file for editing. This still has to be done externally in
notepad, notepad++ or some other text editor (I'm not touching
instructions for vim!).
> By the way, I remember that almost on my case I needed to incluide
> to extra steps before start GRASS
> GRASS_WISH=/c/OSGeo4W/bin/wish.exe
> export GRASS_WISH
> cd /c/OSGeo4W/apps/grass/bin
> grass6
Is this a problem specific to xp/vista 64-bit? Can you give us more
details on the error messages you receive? I believe the setting of
GRASS_WISH should be handled by etc/Init.sh. So if this isn't working
on x64 this should be fixed.
> Finally, now I get grass65 and not grass64, so I suggest update this.
Done.
-Colin
> So, Colin and colleagues, THANKS a lot!!!
> miltinho
> 2009/3/28 Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>
>> Hi Colin,
>> Sorry, I really forgot the zlib-devel. My mistake.
>> But now I compiled and I have other issue.
>> When I start MSys, and define GRASS_WISH,
>> and execute GRASS I get the box to select
>> my MAPSET. After that I get the following error message:
>> This application has failed to start
>> because libintl3.dll was not found.
>> Re-installing the application may fix this problem.
>> Any idea? I need do compile GRASS again (how can I recompile?).
>> Best wishes
>> miltinho
>> Toronto, CA
>> 2009/3/28 Colin Nielsen <colin.nielsen at gmail.com>
>>> I believe you're missing the zlib-devel package, it contains zlib.h.
>>> (Re-)install this package, then try again. If it still fails, verify
>>> that zlib.h is in /osgeo4w/include. If it is there but is still
>>> failing let us know.
>>> -Colin
>>> On Sat, Mar 28, 2009 at 4:47 PM, Milton Cezar Ribeiro
>>> <miltinho.astronauta at gmail.com> wrote:
>>> > Dear Colin,
>>> > Thank you very much for your great work.
>>> > I am trying to follow your steps on a 64bit Vista Machine,
>>> > and got the following error.
>>> > checking for socket... no
>>> > checking for socket in -lsocket... no
>>> > configure: warning: *** Unable to locate socket() function.
>>> > checking for location of zlib includes...
>>> > checking for zlib.h... no
>>> > configure: error: *** Unable to locate zlib includes.
>>> > Any idea?
>>> > Best wishes,
>>> > milton
>>> > Toronto, CA
>>> >> I just wanted to announce that the CompileOnWindows wiki entry
>>> >> <http://trac.osgeo.org/grass/wiki/CompileOnWindows> is finished and
>>> >> now allows anyone to develop grass on windows (vista or xp) through
>>> >> the mingw/msys system with no dependency compiling and relatively
>>> >> little extra work (thanks to jef for solving all remaining issues by
>>> >> adding the mingw-libs package to the wiki).
>>> >> -Colin
>>> >> _______________________________________________
>>> >> grass-windows mailing list
>>> >> grass-windows at lists.osgeo.org
>>> >> http://lists.osgeo.org/mailman/listinfo/grass-windows
