[GRASS-dev] GRASS 7 configure fails on Mac
William Kyngesburye
woklist at kyngchaos.com
Mon Mar 30 14:29:35 EDT 2009
Look in config.log to see why.
On Mar 30, 2009, at 12:56 PM, Michael Barton wrote:
> I just did an svn update from trunk and tried to configure GRASS 7
> prior to compiling. I'm using the same configure string that worked
> successfully 48 hours ago. But configure failed with an geos-config
> error (below). Is this a bug, or do I need to change my config
> string to something different?
> Michael
> ========= error =======
> checking for gdal-config... /Library/Frameworks/GDAL.framework/
> Programs/gdal-config
> checking whether to use GEOS... yes
> checking for geos-config... no
> configure: error: *** couldn't find geos-config
> ========= configure string - used to work ==========
> ./configure --with-freetype --with-freetype-includes="/Library/
> Frameworks/FreeType.framework/unix/include/freetype2 /Library/
> Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/
> Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/
> Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-
> proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-
> proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-
> share=/Library/Frameworks/PROJ.framework/Resources/proj --with-jpeg-
> includes=/Library/Frameworks/UnixImageIO.framework/unix/include --
> with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --
> with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/
> include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/
> unix/lib --with-tiff-includes=/Library/Frameworks/
> UnixImageIO.framework/unix/include --with-tiff-libs=/Library/
> Frameworks/UnixImageIO.framework/unix/lib --without-postgres --
> without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/
> Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/
> Library/Frameworks/SQLite3.framework/unix/include --with-fftw-
> includes=/Library/Frameworks/FFTW3.framework/unix/include --with-
> fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --
> with-cxx --with-opengl=aqua --without-readline --prefix=/
> Applications/GRASS --enable-macosx-app --with-python=/usr/bin/python-
> config --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.9.2/bin/
> wx-config --without-cairo --with-tcltk-includes="/Library/Frameworks/
> Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /
> Library/Frameworks/Tk.framework/PrivateHeaders"
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a
bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
