[GRASS-dev] Re: [GRASS GIS] #540: wxGUI - Map Display only in the
task bar
trac at osgeo.org
Mon Mar 30 15:40:15 EDT 2009
#540: wxGUI - Map Display only in the task bar
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: wx-GUI, task bar
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by hellik):
Replying to [ticket:540 hellik]:
> GRASS-devel6, build from source rev. 36355
> the starting window is ok, i can choose the nc-dataset
> the Layer Manager appears normally, but the Map display is only in the
task bar
> and the following erros message:
> Traceback (most recent call last):
> File "c:\OSGeo4W\apps\grass\grass-6.5.svn\etc\wxpython\gui
> _modules\mapdisp_window.py", line 536, in OnIdle
> self.UpdateMap(render=True)
> _modules\mapdisp_window.py", line 635, in UpdateMap
> windres=windres)
> _modules\render.py", line 915, in Render
> os.environ["GRASS_REGION"] = self.SetRegion(windres)
> _modules\render.py", line 717, in SetRegion
> region = self.AdjustRegion()
> _modules\render.py", line 504, in AdjustRegion
> self.region["nsres"] = mapheight / self.height
> ZeroDivisionError
> float division
> if i do the same action in osgeo4w-GRASS64-rc, everything is ok.
> best regards
> Helmut
also in the actual grass6.4svn of Osgeo4W in Win Vista
Best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/540#comment:2>
