[GRASS-dev] GRASS 7 configure fails on Mac
Martin Landa landa.martin at gmail.com
Mon Mar 30 17:26:47 EDT 2009
2009/3/30 Michael Barton <michael.barton at asu.edu>:
> Neither one of these work, even though they correctly map to the location of
> geos-config and the lib and include directories (set up from your frameworks
> packages). I'll try to compile without GEOS, though I don't know what I'll
> be missing there.
I changed default option to --with-geos=no, so you don't need to
modify your configuration script. If you compile with geos you can use
more spatial operators (touches, disjoint, etc.) in v.select.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
