[GRASS-dev] GRASS 7 configure fails on Mac
Martin Landa
landa.martin at gmail.com
Tue Mar 31 01:02:46 EDT 2009
2009/3/31 Michael Barton <michael.barton at asu.edu>:
> So you're saying that vdigit doesn't work again because of the geos problem?
again, problem? ;-)
I wasn't expecting that if you have GEOS installed that geos_c.h is
not available. If so than vector libs compilation fail. In this case
checking for geos-config is not enough.
M.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
