[GRASS-dev] [GRASS GIS] #578: quote column names to avoid SQL
reserved word collision
trac at osgeo.org
Fri May 1 04:56:44 EDT 2009
#578: quote column names to avoid SQL reserved word collision
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: Vector | Version: svn-develbranch6
Keywords: v.in.ogr, SQL | Platform: All
Cpu: All |
moved here from GDAL bug # 2965
http://trac.osgeo.org/gdal/ticket/2965
v.in.ogr will not read GPX format as input because OGR's GPX driver
creates a DB field called "time" for the timestamp. GRASS chokes on this
because TIME is a SQL reserved word for some backends (DBF doesn't like
it, SQLite is ok with it).
workaround: use the cnames= option to rename the TIME field.
suggestion by rouault:
"''There is no reason for the GPX driver not to use "time" as a field
name. I think you should report it rather to the GRASS project. They
should likely quote the field names (provided that it supports that). This
is what the PG and MySQL driver in OGR do, so you can use any name, even
if it is a SQL reserved keyword.''"
comments?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/578>
