[GRASS-dev] [GRASS GIS] #579: configure doesn't like debian's
wx-config 2.8 renaming
trac at osgeo.org
Sat May 2 09:11:11 EDT 2009
#579: configure doesn't like debian's wx-config 2.8 renaming
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Installation | Version: svn-develbranch6
Keywords: configure | Platform: Linux
Cpu: Unspecified |
for the official Debian package we need to specify which wx-config to use
because 2.6 can be installed on the same system.
'--with-wxwidgets=/path/to/wx-config2.8' should work, but it doesn't
because configure.in explicitly only accepts a binary called 'wx-config'
on line ~ 1740:
if test "`basename $with_wxwidgets`" = "wx-config" ; then
WX_CONFIG="$with_wxwidgets"
fi
can we change it to be more like --with-python= ?
if test "$with_python" != "yes" ; then
PY_CONFIG="$with_python"
fi
the real wx-config binary on debian is hidden behind some symlinks but on
a system with wx2.6 on it as well needs to be set to '--with-
wxwidgets=/usr/lib/wx/config/gtk2-unicode-release-2.8'
this is related to debian bug # 526200:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=526200
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/579>
