[GRASS-dev] Re: [GRASS GIS] #571: v.db.addcol: fails if path
contains spaces
trac at osgeo.org
Tue May 5 07:08:51 EDT 2009
#571: v.db.addcol: fails if path contains spaces
Reporter: pcav | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by pcav):
GRASS > db.connect -p
driver:dbf
database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
schema:
group:
GRASS > v.db.connect -p incrociata at paolo
Vector map <incrociata at paolo> is connected by:
layer <1> table <incrociata> in database </home/paolo/Desktop/test/prova
due/paolo/dbf/> through driver <dbf> with key <cat>
GRASS >
Ticket URL: <https://trac.osgeo.org/grass/ticket/571#comment:5>
