[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
GRASS GIS trac at osgeo.org
Tue May 5 09:55:15 EDT 2009
  Reporter:  timmie        |       Owner:  timmie
      Type:  defect        |      Status:  reopened
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  6.4.0 RCs
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  x86-32
Changes (by timmie):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 One small issue:
 When GRASS is started from the menu shortcut, there is still an empty dos
 CLI in the background.
 I think there should somewhere be called
 pythonw.exe instead of python.exe
 But I do not know how to correct this as I do not understand the
 interactions between
 Grass64.bat -wxpython
 and
 etc/Init.bat
 Maybe someone can help here?
Ticket URL: <https://trac.osgeo.org/grass/ticket/570#comment:16>
