[GRASS-dev] Problem v.in.ascii (GRASS6.4.0RC4)
roberto.marzocchi roberto.marzocchi at gmail.com
Tue May 5 16:55:48 EDT 2009
I have the same problem in the command line (using fs='  ') and using
the GUI without quoting
maybe i have a problem with libraries....?
R
Moritz Lennert ha scritto:
> On 05/05/09 17:45, roberto marzocchi wrote:
>> in attached the input file
>> in grass6.3.0 the command run, the problem is only with the last
>> grass version
> Have you tried quoting the fs, i.e.:
> v.in.ascii -z input=fle_input  output=name_output format=point fs=' '
> skip=0 x=1 y=2 z=3 cat=0 --overwrite
> Running it without quoting, I get:
> ERROR: y column number > minimum last column number
>        (incorrect field separator?)
> With quoting it works (in the grass6 development branch).
> How are you running this command ? On the command line ? In the GUI ?
> Moritz
>> R
>> 2009/5/5 Moritz Lennert <mlennert a club.worldonline.be
>> <mailto:mlennert a club.worldonline.be>>
>>         fs=  skip=0 x=1 y=2 z=3 cat=0 --overwrite --quiet
>>         Output:
>>         Segmentation fault
>>         dbmi: Protocol error
>>         Grass import correctly the points, but don't create the
>>         associated table. anyone know the reason?
>>     Is there any attribute data contained in the input file ? It would
>>     help if you sent us at least the first few lines of the data.
>>     Also fs= seems weird. What is the field separator in the file ?
>>     Moritz
>> Please consider the environment before printing this mail note!
