[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
Wed May 6 05:58:45 EDT 2009
Moritz Lennert wrote:
> >  When GRASS is started from the menu shortcut, there is still an empty dos
> >  CLI in the background.
> AFAIK, this DOS CLI is necessary for the functioning of GRASS, notably
> running the temp file cleaning operations at the end. So, until we have
> reengineered the Windows startup logic, I don't think we can get rid of it.
If enough users are likely to want to use the wxPython GUI as the main
interface, I'd consider adding a Python-based startup as an
alternative to grassXX[.bat] and Init.{sh,bat}.
This should be invoked via pythonw on Windows, and should redirect
std{out,err} to files. Also, if GISBASE isn't already defined, set it
from a registry key.
A command-line-only interface is of relatively little use on Windows,
due to the absence of monitors.
