[GRASS-dev] Re: [GRASS GIS] #577: v.in.ogr: imported GPX file
results in N=0, W=0
trac at osgeo.org
Wed May 6 07:48:30 EDT 2009
#577: v.in.ogr: imported GPX file results in N=0, W=0
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: v.in.ogr, gpx
Platform: Linux | Cpu: x86-32
Comment (by mmetz):
Grass vector extends are calculated when topology is built, based on the
primitives, which happens after all layers were imported by v.in.ogr, IOW
grass vector extends should be calculated independent of the OGR layer
extends. If all features are somewhere around 170, -46 and nowhere near
0,0, v.info should report extends accordingly. That's why I think there
may be a bug in the vector libraries when building topology because
v.out.ascii confirmed that no points where anywhere near 0,0.
Hamish, can you do a bit more testing? Are the extends still wrong
* after rebuilding topology with v.build?
* when importing track_points only from the GPX file?
* when importing all shapefiles at once into one grass vector?
* when importing the shapefile track_points only?
v.in.ogr could also be modified to skip empty OGR layers (Feature Count:
0). I don't know if there are OGR-recognized vector formats where there
can be some info in a layer with no features, then empty layers should not
be skipped.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/577#comment:3>
