[GRASS-dev] Problem v.in.ascii (GRASS6.4.0RC4)
Hamish
hamish_b at yahoo.com
Wed May 6 10:29:50 EDT 2009
Markus wrote:
> I can reproduce the problem:
me too, in 6.4.0svn and 6.5svn, but not in 6.3.0
> Scanning input for column types...
> Maximum input row length: 35
> Maximum number of columns: 10
> Minimum number of columns: 4
> Importing points...
> 100%
> Populating table...
> dbmi: Protocol error
> No good.
In GRASS 6.3.0 I get:
[with --verbose to show column scan results (my feeling is to move
that back to the standard messages because it is so helpful in self-
debugging)]
Maximum number of columns: 4
Column: 1 type: double
Column: 2 type: double
Column: 3 type: double
Column: 4 type: string length: 8
Importing points...
Populating table...
Building topology ...
108 primitives registered
but in GRASS 6.4.0rc4, 6.5 I get:
Column: 5 type: string length: 0
Column: 6 type: string length: 0
Column: 7 type: string length: 0
Column: 8 type: string length: 0
Column: 9 type: string length: 0
Column: 10 type: string length: 0
Importing points...
100%
Populating table...
Minimum number of columns: 4 -> 10
I don't know which should be "right" or "wrong", but the change possibly
happened here:
http://trac.osgeo.org/grass/changeset/25353
Hamish
