[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone
GRASS install
trac at osgeo.org
Thu May 7 01:17:54 EDT 2009
#570: startup problem with standalone GRASS install
Reporter: timmie | Owner: timmie
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
timmie wrote:
> Where can upload a ZIP for verification?
verification of what? what's in the ZIP file?
> One small issue: When GRASS is started from the menu shortcut,
> there is still an empty dos CLI in the background.
as discussed on grass-dev,
- in the OSGeo4W installer you get a grass terminal session in a dos box
using the wx gui
- in the OSGeo4W installer you get a blank dos box when using the tcltk
gui until you exit the gui when it becomes a grass terminal session (patch
in osgeo4w bug # 83 http://trac.osgeo.org/osgeo4w/ticket/83)
- in Colin's stand-alone installer the empty dos box is now minimized by
default. maybe some valuable error messages could end up there; maybe
Glynn will rewrite grass.bat into a general launch_grass.py.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/570#comment:17>
