[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
GRASS GIS trac at osgeo.org
Thu May 7 04:36:35 EDT 2009
  Reporter:  timmie        |       Owner:  timmie
      Type:  defect        |      Status:  reopened
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  6.4.0 RCs
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by timmie):
 Replying to [comment:17 hamish]:
 > > Where can upload a ZIP for verification?
 > verification of what? what's in the ZIP file?
 Yes. I mean, now it works on my computer.
 But I guess we need to verify if others with different python
 installations are also affected.
 Take the contents of the ZIP to compare what has changed.
 > > One small issue: When GRASS is started from the menu shortcut,
 > > there is still an empty dos CLI in the background.
 Sorry, I should have written:
 An empty DOS window with no command promp. Just a black window.
 >  - in Colin's stand-alone installer the empty dos box is now minimized
 by default. maybe some valuable error messages could end up there; maybe
 Glynn will rewrite grass.bat into a general launch_grass.py.
 I think after my replacement of the win32* packages in the GRASS python
 install, Colins minimisation doesn't work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/570#comment:18>
