[GRASS-dev] v.db.calc
    Martin Landa
    landa.martin at gmail.com
    Thu May  7 09:25:44 EDT 2009
2009/5/7 Glynn Clements <glynn at gclements.plus.com>:
>> I would vote for both approaches. User can decide what he prefers via
>> environmental variable, e.g. GRASS_SQLITE_PER_MAPSET.
> There's no reason to use an environment variable. This should be dealt
> with by the database setting (VAR or dblink). If it refers to a
> directory, use a <mapname>.db file for each map. Otherwise treat it is
> the name of an SQLite database file to use for all maps.
Right.
M.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
