[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
Fri May 8 21:01:52 EDT 2009
Martin Landa wrote:
> >> missing. Question: do we need python-config? wxGUI extensions are
> >> build using setup.py. So --with-python could check only if 'python'
> >> binaries are available (?)
> to the question: any objection to make python-config checking
> optional? So --with-python will check if python binaries are available
> and optionally also python-config.
Whatever works, really.
Preferably, whatever works with the wxPython binary packages from
wxpython.org, rather than requiring a GRASS-specific version.
