[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
Sat May 9 07:30:48 EDT 2009
Martin Landa wrote:
> >> to the question: any objection to make python-config checking
> >> optional? So --with-python will check if python binaries are available
> >> and optionally also python-config.
> > Whatever works, really.
> > Preferably, whatever works with the wxPython binary packages from
> > wxpython.org, rather than requiring a GRASS-specific version.
> OK, done in r37060.
Er, I think I misread "python-config" as "wx-config".
While this change is reasonable enough in itself, it doesn't help with
the issue of needing a working wx-config program in order to build the
extensions.
