[GRASS-dev] Re: [GRASS GIS] #580: WinGRASS:
$GISBASE/etc/gui/scripts/ require something like $(EXE) to run
trac at osgeo.org
Sun May 10 04:14:35 EDT 2009
#580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment (by hamish):
I may have solved the problem of the GUI scripts not running on WinGRASS
with r37085, 86, 87. They were missing .bat wrappers. leaving bug open as
I haven't properly tested it.
'''TODO'''
* grass 7: (gui/scripts/Makefile) fix (wildcard *.*) and then use with
create.bat:
* wxpython/scripts/Makefile: do p.* need .bat files too?
* similar thing needed to get g.gui launcher to work on WinGRASS?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/580#comment:1>
