[GRASS-dev] Re: [GRASS GIS] #587: svn versions should better reflect svn rev
GRASS GIS trac at osgeo.org
Sun May 10 19:20:16 EDT 2009
  Reporter:  hamish       |       Owner:  martinl
      Type:  enhancement  |      Status:  reopened
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  6.4.0 RCs
Resolution:               |    Keywords:  g.version
  Platform:  All          |         Cpu:  All
Comment (by hamish):
 thanks for mentioning `svn info`, I hadn't seen that.
 However, AFAICT "`svn info`" and "`svnversion`" both give the rev number
 of the entire repo, not the latest change to that branch.
 using the "`svn log`" method would keep the version unchanged for e.g.
 GRASS 5.4.2 since the last time that branch was actually modified.
 otherwise all branches+trunk versions change each time any modification is
 made globally (e.g. to grass-web or trunk), when in fact they haven't
 changed at all.
 the downside of `svn log` is that it is rather slow and requires internet
 access.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:17>
