[GRASS-dev] python grass problems on OSX (Incompatible library version for module)
massimo di stefano massimodisasha at yahoo.it
Mon May 11 02:01:39 EDT 2009
Hi Hamish, All,
Il giorno 11/mag/09, alle ore 01:08, Hamish ha scritto:
> massimo di stefano wrote:
>> but i gett errors about :
>> "Incompatible library version for module"
> you need to rebuild GRASS completely, or untangle multiple
> installations. i.e. do a full 'make distclean' and re-make.
> Hamish
I removed the graas_trunk source code and re-download a new one and
rebuild it using these configure [1]
but the problem persists.
[1]
./configure --with-freetype --with-freetype-includes="/Library/
Frameworks/FreeType.framework/unix/include/freetype2 /Library/
Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/
Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/
Frameworks/gdal.framework/Programs/gdal-config --with-proj --with-proj-
includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-
libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/
Library/Frameworks/PROJ.framework/Resources/proj --with-jpeg-includes=/
Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-
libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-
includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-
png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-
tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --
with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --
without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/
Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/
Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/
Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/
Library/Frameworks/FFTW3.framework/unix/lib --with-cxx --with-
opengl=aqua --with-x --without-glw --with-tcltk-includes="/Library/
Frameworks/Tcl.framework/Headers /Library/Frameworks/Tk.framework/
Headers /Library/Frameworks/Tk.framework/PrivateHeaders" --with-python
--with-wxwidgets=/usr/bin/wx-config --with-postgres --with-postgres-
includes=/usr/local/pgsql/include/ --with-postgres-libs=/usr/local/
pgsql/lib/ --prefix=/usr/local --with-geos=/Library/Frameworks/
GEOS.framework/Versions/3/Programs/geos-config --with-pthread --enable-
largefile --with-ffmpeg --with-ffmpeg-includes=/Users/Shared/
Development/ossim_dependencies/include/ffmpeg/ --without-cairo
Massimo Di Stefano
massimodisasha a yahoo.it
epifanio on   irc.freenode.net  /join gfoss
Chiacchiera con i tuoi amici in tempo reale!
 http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
