massimo wrote:
> I removed the graas_trunk source code and re-download a new
> one and rebuild it using these configure [1]
> but the problem persists.
what's OSX's version of ldd called?
if you run that within the broken environment it will tell you which
libraries it is trying to use.
Hamish
