[GRASS-dev] re: python grass problems on OSX (Incompatible
library version for module)
massimo di stefano
massimodisasha at yahoo.it
Mon May 11 04:40:01 EDT 2009
adding the debugging symbols to the script :
GRASS 7.0.svn (spearfish60):~ > i.img2rr image1=geology
+ '[' -z /usr/local/grass-7.0.svn ']'
+ '[' image1=geology '!=' @ARGS_PARSED@ ']'
+ exec g.parser /usr/local/grass-7.0.svn/scripts/i.img2rr image1=geology
+ '[' @ARGS_PARSED@ '!=' @ARGS_PARSED@ ']'
++ g.gisenv
+ eval 'GISDBASE='\''/Users/Shared/grassdata'\'';'
'LOCATION_NAME='\''spearfish60'\'';' 'MAPSET='\''PERMANENT'\'';'
'GRASS_GUI='\''wxpython'\'';'
++ GISDBASE=/Users/Shared/grassdata
++ LOCATION_NAME=spearfish60
++ MAPSET=PERMANENT
++ GRASS_GUI=wxpython
+ : /usr/local/grass-7.0.svn /Users/Shared/grassdata spearfish60
PERMANENT
+ LOCATION=/Users/Shared/grassdata/spearfish60/PERMANENT
+ export DYLD_FRAMEWORK_PATH=/var/tmp/XcodeBuilds/Release
+ DYLD_FRAMEWORK_PATH=/var/tmp/XcodeBuilds/Release
+ export OSSIM_PREFS_FILE=/Users/sasha/Desktop/ossim_preference
+ OSSIM_PREFS_FILE=/Users/sasha/Desktop/ossim_preference
+ /private/var/tmp/XcodeBuilds/Release/img2rr /Users/Shared/grassdata/
spearfish60/PERMANENT/cellhd/geology
MPI running with 1 processors...
ERROR: Incompatible library version for module. You need to rebuild
or untangle multiple installations.
these the output from otool :
GRASS 7.0.svn (spearfish60):~ > otool -L `which g.parser`
/usr/local/grass-7.0.svn/bin/g.parser:
/usr/local/grass-7.0.svn/lib/libgrass_gis.dylib (compatibility
version 7.0.0, current version 7.0.0)
/usr/local/grass-7.0.svn/lib/libgrass_datetime.dylib (compatibility
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version
1.2.3)
/usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current
version 1.0.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
version 111.1.3)
Il giorno 11/mag/09, alle ore 10:14, Markus Neteler ha scritto:
> On Mon, May 11, 2009 at 9:49 AM, massimo di stefano
> <massimodisasha a yahoo.it> wrote:
>> I tried :
>> cd /Users/Shared/source/grass_trunk/
>> svn up
>> make distclean
>> export CXXFLAGS="-arch ppc -arch i386 -Os" ; export CFLAGS="-arch
>> ppc -arch
>> i386 -Os" ; export LDFLAGS="-arch ppc -arch i386 -Os" ; export
>> GDAL_BIN=/Library/Frameworks/gdal.framework/unix/bin/ ; export
>> NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
>> ./configure .. .. .. --prefix=/usr/local/
>> make
>> sudo make install
>> then i copied the the script i.img2rr inside the scripts directory :
>> cp i.img2rr /usr/local/grass-7.0.svn/scripts
>> chmod a+x /usr/local/grass-7.0.svn/scripts/i.img2rr
>> run grass70
>> GRASS
>> i tried the command "ldd"
>> but it is not found on my system
>> a google search tell me about "otool" as an osx "ldd" replacment
>> inside grass shell :
>> otool -L `which i.img2rr`
>> /usr/local/grass-7.0.svn/scripts/i.img2rr: is not an object file
> otool won't work on scripts but on binaries.
> please try
> Additionally, you can do shell debugging by changing the first line of
> your script from
> #!/bin/sh
> to
> #!/bin/sh -x
> This may help to see which libs are picked up.
> Markus
Chiacchiera con i tuoi amici in tempo reale!
http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
