[GRASS-dev] python grass problems on OSX (Incompatible library version for module)
Hamish hamish_b at yahoo.com
Mon May 11 04:42:49 EDT 2009
massimo  wrote:
> Maybe thes can help ?
> i runned ottol -L on the grass modules and on gdalinfo executable
$ grep '6\.[0-9]' ottol_grass_modules.txt
        /Library/Frameworks/PROJ.framework/Versions/4.6/PROJ (compatibility version 6.0.0, current version 6.5.0)
I'm not really sure if that's GRASS 6.0 and 6.5 or if something else has
those versions. but maybe it's the gdal-grass plugin that needs to be
rebuilt for grass 7??
Hamish
