[GRASS-dev] v.out.ogr patch: support OGR "update"
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Mon May 11 05:29:26 EDT 2009
Dear all,
I have attached a very small patch to v.out.org against the
version in 6.4.SVN. It adds a "-u" flag that allows users
to update data in existing OGR sources. It's the same as
ogr2ogr's "-update" option and _very_ important for being able
to write layers as tables into existing spatial databases.
It should not be able to break any existing functionality.
If a data source does not support updates (like Shapefiles),
then Ogr_Dr_open() behaves the same as Ogr_Dr_CreateDataSource().
Despite the update, I have not been able to successfully
write OGR features to an existing (or new) SQLite DB.
OGR_L_CreateFeature() results in this error from the SQLite driver
after the first feature has been written:
ERROR 1: sqlite3_step() failed:
   SQL logic error or missing database
Strangely, the first feature is written into the table just fine,
but the error appears for all consecutive writes.
I will have to do more tests to see if this is an SQLite
and GRASS specific problem (ogr2ogr works fine).
Cheers,
Ben
Benjamin Ducke
Senior Geospatial Consultant
Oxford Archaeology
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090511/175cf880/v.out.ogr-0001.bin
