[GRASS-dev] Re: [GRASS GIS] #597: Digitize tool won't work
trac at osgeo.org
Mon May 11 13:54:15 EDT 2009
Reporter: vince | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: digitize
Platform: MacOSX | Cpu: x86-64
Comment (by vince):
Ok, fine thanks a lot and sorry for the inconvenience. I'm going to alter
the port to fetch the svn version instead, at least until a stable version
with correct 64-bit OS X support is released. Anyhow, a full 64-bit build
will not be possible until Wxwidgets itself is 64-bit safe, that is the
Cocoa port is finished. At that time, only Qgis offer full 64-bit mode
under OS X, since Qt 4.5 moved to Cocoa.
Thanks again
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:7>
