[GRASS-dev] Error on attempted read access to a vector map in PERMANENT
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Wed May 13 08:05:20 EDT 2009
Dear all,
I just came across an issue with vector maps in the PERMANENT mapset
and was wondering if anyone else had the same problem.
Whenever I want to get read access to a DBF attribute table for
a vector file in PERMANENT (while logged into a user mapset),
e.g. using "db.select <map>", I get:
DBMI-DBF driver error:
Table '<map>' doesn't exist.
Error in db_open_select_cursor()
I also get the "select cursor" error from other modules, such as
g.copy. Interestingly, I can log into the PERMANENT mapset and
then things work fine. I have checked the Unix file permissions
and they are OK. I have checked different GRASS location and
they consistently have the same problem.
I have not checked any DBMI other than DBF.
I tested this on a 6.4 SVN snapshot from May 9th 2009.
Cheers,
Ben
Benjamin Ducke
Senior Geospatial Consultant
Oxford Archaeology
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
