[GRASS-dev] Error on attempted read access to a vector map in
PERMANENT
Markus Neteler
neteler at osgeo.org
Thu May 14 05:35:21 EDT 2009
On Thu, May 14, 2009 at 10:51 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 13/05/09 14:28, Markus Neteler wrote:
>> On Wed, May 13, 2009 at 2:05 PM, Benjamin Ducke
> AFAIK, you can. The problem is that db.* modules use the mapset database
> definition by default, but if you explicitely set the databse= parameter to
> point to the dbf directory in PERMANENT, you should be able to access the
> data.
ah ok - once this is verified please update/add a note in the
db/databaseintro.html
files.
thanks
Markus
