[GRASS-dev] Re: [GRASS GIS] #604: /usr/lib/grass64/etc/grass-run.sh
 does not
 work properly when called by gis.m to execute in a external xterm
    trac at osgeo.org
    Sun May 17 02:33:25 EDT 2009
#604: /usr/lib/grass64/etc/grass-run.sh does not work properly when called by
  Reporter:  frankie   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  Tcl       |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  xterm
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:13 glynn]:
 > Okay; it appears to be a bug in Gronsole::run_xterm
 > (lib/gtcltk/gronsole.tcl):
      exec -- $env(GISBASE)/etc/grass-xterm-wrapper -name xterm-grass -e
 env(GISBASE)/etc/grass-run.sh $cmd &
 > The command is being treated as a string, and passed as a single
 > argument. It should be a list, and each element should be a
 > separate argument to "exec". See the "term" procedure in
 > runandoutput.tcl for an example of calling "exec" with a list
 > of arguments.
 ok, thanks.
 but more fundamentally the $cmd string is passed from
 gis.m/runandoutput.tcl as a whole concatenated string, and so run_term in
 gtcltk/gronsole.tcl has no $args list to work with.
 and how can runandoutput.tcl know how to parse apart the "Run (in Xterm)"
 command string into a series of without extra quoting parsing and logic?
 As a "document it and walk away" solution I tried replacing "" with {} for
 the quoting in my input command, but that didn't help at all.
 fwiw1: all modules in the gmmenu.tcl menu called with "term" are single
 element, ie just the name of the module. so this is just a problem with
 the "Run (in Xterm)" button in the Output window.
 fwiw2: on native WinGRASS all 4 "Run" buttons fail for the v.db.select
 example listed earlier in this bug report, but pass for 'g.proj -p'.
 aside: I notice gronsole.tcl uses "&" at the end of the cmd.exe run_xterm.
 does that work on windows?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/604#comment:14>
