[GRASS-dev] Re: [GRASS GIS] #606: WinGRASS GIS.m: broken newlines
in output window
trac at osgeo.org
Mon May 18 06:07:44 EDT 2009
#606: WinGRASS GIS.m: broken newlines in output window
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Tcl | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass gis.m
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
Replying to [comment:2 glynn]:
> Don't use Tcl's "update" command unless you are able and willing
> to make the function and everything which calls it re-entrant.
> Even then, don't use it, as someone will eventually modify the
> code without considering the re-entrancy issues, and we'll end
> up spending days trying to track down a hard-to-reproduce bug.
> Again.
ok. note that I was just cutting and pasting it from two or three lines
down in the same function where it was already used.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/606#comment:5>
