[GRASS-dev] [GRASS GIS] #608: GIS.m: Lat/Lon support broken in Map
Display zooms
trac at osgeo.org
Tue May 19 10:35:02 EDT 2009
#608: GIS.m: Lat/Lon support broken in Map Display zooms
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: Tcl | Version: 6.4.0 RCs
Keywords: gis.m, LL | Platform: All
Cpu: All |
when in a lat/lon location the gis.m Map Display zooming is quite broken.
Previously you'd get many "Error setting region: child process exited
abnormally [ok]" popping up*, and if you zoom out to the global scale
everything pretty much goes haywire.
[*] because `g.region n=$mapcanvas_value>90`
there's a partial fix in SVN now (r37285) -- it will switch into
constrained mode if you try to zoom out beyond 90 degrees N,S. But it's
not quite right, you still get white borders and the canvas coords get all
messed up after that. I expect that besides switching to constrained mode
it needs to either recalc the resolution after resetting N,S to 90, or
just break out of the routine it's in because the premise for being there
becomes invalid.
I've taken it about as far as I can go.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/608>
