[GRASS-dev] Re: [GRASS GIS] #604: /usr/lib/grass64/etc/grass-run.sh
does not
work properly when called by gis.m to execute in a external xterm
trac at osgeo.org
Tue May 19 18:59:01 EDT 2009
#604: /usr/lib/grass64/etc/grass-run.sh does not work properly when called by
Reporter: frankie | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Tcl | Version: 6.4.0 RCs
Resolution: | Keywords: xterm
Platform: Linux | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:19 hamish]:
> ok, with r37291 something finally works-
Okay, that's essentially the code which "term" uses. But you can simplify
it a bit, as there's no need to split $cmd into $cmd_exe and $args; this
should work just as well:
eval [list exec -- $env(GISBASE)/etc/grass-xterm-wrapper -name xterm-grass
-e $env(GISBASE)/etc/grass-run.sh] $cmd &
After all, the command name is just the first argument to grass-run.sh.
> it splits this up by spaces:
v.db.select roads where={label ~ 'highway'}
Yep; a brace-delimited string must have the braces at the beginning and
end; you can't put them in the middle like with quotes in bash.
Ticket URL: <https://trac.osgeo.org/grass/ticket/604#comment:20>
