[GRASS-dev] grass python module
    Markus Neteler
    neteler at osgeo.org
    Fri May 22 03:32:30 EDT 2009
On Fri, May 22, 2009 at 12:14 AM, Martin Landa <landa.martin at gmail.com> wrote:
> 2009/5/8 Glynn Clements <glynn at gclements.plus.com>:
>> Currently, those modules are named swig.grass, swig.vector, etc. That
>> was done to avoid a collision over "import grass". But "swig" is a
>> rather generic prefix to use. I had thought about changing it from
>> "swig.*" to "grass.*", and renaming "grass" to e.g. "grass.script".
>> The question is whether e.g. "grass.vector" should contain the
>> functions from grass.py or the SWIG functions for the vector library.
>> IOW, which one gets precedence? Or should we make them equal and just
>> have grass.script.vector and grass.swig.vector?
>> And should "swig" even be visible, or should it be e.g.
>> "grass.lib.vector"?
> It seems to me 'lib' as better name then 'swig'.
> Done in
> r37345
> r37346
> r37347
> r37348
Before backporting, could it be possible to move out the include part into
swig/include/
Here what Glynn suggested:
On Wed, May 6, 2009 at 12:13 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> in order to facilitate the creation of other bindings, I suggest to move the
>>  swig/python/*.i
>> files into
>>  swig/include/
>> Then the various language wrappers could include from there.
> common.i, grass.i, my_typemaps.i and utils.i are language-specific,
> but the rest could be moved.
Markus
