[GRASS-dev] Re: [GRASS GIS] #111: r.los fails in WinGRASS with high
values for max_dis parameter
trac at osgeo.org
Fri May 22 12:42:13 EDT 2009
#111: r.los fails in WinGRASS with high values for max_dis parameter
Reporter: gsancho | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords: wingrass r.los
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
Replying to [comment:17 gsancho]:
> I have also made some tests with r.los operation and it keep
> failing (as it does in other versions)
what version do you test with? same spearfish command line as in the
original bug report?
I've just tested r.los in the latest stand-alone WinGRASS installer and it
the only problem I noticed was that the G_percent() text only gets
displayed as 100% after the process is complete, after any module output
(run from msys command line).
I tested these:
#spearfish
r.los in=elevation.dem output=tr_vis \
coordinate=599490,4920855 max_dist=10000
r.los input=elevation.dem output=los \
coordinate=599505,4921010 max_dis=2525
#NC_spm_08
r.los in=elevation out=ele.los coord=637500,221750 \
obs_elev=42 max=10000
all without crashing.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/111#comment:20>
