[GRASS-dev] Re: [GRASS GIS] #612: g.html2man: parsing leads to man page errors
GRASS GIS trac at osgeo.org
Fri May 22 21:37:53 EDT 2009
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  6.5.0
 Component:  Docs         |     Version:  6.4.0 RCs
Resolution:               |    Keywords:  g.html2man
  Platform:  Unspecified  |         Cpu:  All
Comment (by glynn):
 Replying to [ticket:612 hamish]:
 > tools/g.html2man has a number of parsing problems.
 > there are a few like cairodriver.1 which happen to start lines with ".",
 which gets parsed incorrectly by the man program. e.g. in cairodriver it
 lists ouput formats, and the '.pn' of .png gets hijacked and all those
 image types end up missing from the resulting man page.
 I've committed some fixes in r37386. Apart from escaping dots and single
 quotes at the beginning of a line, it doesn't remove leading whitespace
 from pre-formatted text and doesn't insert line breaks within .IP "..."
 (this last one only affected d.graph).
 > another popular one is <OL><LI> becoming ..IP instead of .IP (e.g.
 pngdriver.1 just after "Example")
 > and yet another is g.parser.1 where #%multiple: gets eaten.
 I can't reproduce these.
 > detailed list of errors is here:  (scroll down to 'grass-doc')
 > http://lintian.debian.org/maintainer/pkg-grass-
 devel at lists.alioth.debian.org.html#grass
 Note that the "bad whatis" entries correspond to an HTML file which lacks
 a description in the NAME section. This generally only occurs with HTML
 files which aren't generated from --html-description.
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:1>
