[GRASS-dev] Re: [GRASS GIS] #528: wxGUI cmd: r.mapcalc fails (quoting + args with spaces)
GRASS GIS trac at osgeo.org
Sat May 23 07:49:28 EDT 2009
  Reporter:  neteler   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by martinl):
 Replying to [comment:14 hamish]:
 > I just added a patch to this ticket (vs devbr6) which roughly uses
 `shlex.split(command)` to parse the command string in a shell-like way. It
 doesn't actually work but I think it gets close. something like the
 `command = ' '.join(command)` from the Xterm fn is happening so it just
 tries to execute the first letter. Hopefully a more learned pythoner can
 quickly finish the job from here.
 Modified path applied in trunk (r37395), devbr6 (r37396) and relbr64
 (r37397).
 Testing welcomed ...
 Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/528#comment:15>
