[GRASS-dev] reorder tcltk/opengl checks in configure?
Glynn Clements
glynn at gclements.plus.com
Sat May 23 13:06:30 EDT 2009
William Kyngesburye wrote:
> There's only the 2.61 from Xcode. Is that 2.13 an absolute
> requirement or a minimum?
The former.
> I don't see why a newer autoconf shouldn't support an older
> configure.in.
Later versions aren't backwards compatible.
2.13 was the last version before autotools degenerated into an
incomprehensible mess.
