[GRASS-dev] Re: [GRASS GIS] #588: wxGUI: About GRASS GIS window doesn't let you view full lic or devs
GRASS GIS trac at osgeo.org
Sat May 23 22:41:04 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  closed
  Priority:  major         |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  6.4.0 RCs
Resolution:  worksforme    |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Changes (by xpolok00):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 I've downloaded Grass 6.4.0 form SVN
 (grass-6.4.svn_src_snapshot_2009_05_23.tar.gz) and was able to reprodice
 the bug. I found out there's no way (AFAIK) to add scrollbars to
 wx.AboutBox, so i solved the bug by adding two new menu items, "GRASS GIS
 Authors" and "GRASS GIS License" and somewhat modified the original about
 box.
 modified files are:
 * gui/wxpython/wxgui.py
 * gui/wxpython/xml/menudata.xml
 diff patch for wxgui.py:
 $ diff -c wxgui.py patched_wxgui.py
 *** wxgui.py    Sat May 23 09:53:12 2009
 --- patched_wxgui.py    Sun May 24 02:19:34 2009
 *** 52,59 ****
   import gui_modules.globalvar as globalvar
   if not os.getenv("GRASS_WXBUNDLED"):
 !     globalvar.CheckForWx()
   import wx
   import wx.aui
   import wx.combo
 --- 52,61 ----
 ! from wx.lib.dialogs import ScrolledMessageDialog
   import wx
   import wx.aui
   import wx.combo
 *** 88,94 ****
   from   gui_modules.debug import Debug as Debug
   from   icons.icon import Icons as Icons
 ! UserSettings = preferences.globalSettings
   class GMFrame(wx.Frame):
 --- 90,96 ----
 *** 527,535 ****
                                               lchecked=True,
                                               lopacity=1.0,
                                               lcmd=['d.vect', 'map=%s' %
 name])
       def OnAboutGRASS(self, event):
 !         """Display 'About GRASS' dialog"""
           info = wx.AboutDialogInfo()
           # name
 --- 529,551 ----
                                               lchecked=True,
                                               lopacity=1.0,
 name])
 !     def OnGRASSLicense(self, event):
 !         """Display 'GRASS License' dialog"""
 !         licenceFile = open(os.path.join(os.getenv("GISBASE"),
 "GPL.TXT"), 'r')
 !         dialog = ScrolledMessageDialog ( self,
 ''.join(licenceFile.readlines()), 'GRASS GIS License' )
 !         licenceFile.close()
 !         dialog.ShowModal()
 !     def OnGRASSAuthors(self, event):
 !         """Display 'GRASS Authors' dialog"""
 "AUTHORS"), 'r')
 ''.join(licenceFile.readlines()), 'GRASS GIS Authors' )
           # name
 *** 551,563 ****
           # website
           info.SetWebSite(("http://grass.osgeo.org", "The official GRASS
 site"))
           # licence
 "GPL.TXT"), 'r')
 !         info.SetLicence(''.join(licenceFile.readlines()))
           # credits
 !         authorsFile = open(os.path.join(os.getenv("GISBASE"),
 "AUTHORS"), 'r')
 !         info.SetDevelopers([unicode(''.join(authorsFile.readlines()),
 "utf-8")])
 !         authorsFile.close()
           wx.AboutBox(info)
 --- 567,581 ----
           # website
 site"))
           # licence
 !         #licenceFile = open(os.path.join(os.getenv("GISBASE"),
 "GPL.TXT"), 'r')
 !         #info.SetLicence(''.join(licenceFile.readlines()))
 !         #licenceFile.close()
 !         info.SetLicence('Distributed under GNU License, Version 2, June
 1991.\nUse menu Help - GRASS GIS License for more details')
           # credits
 !         #authorsFile = open(os.path.join(os.getenv("GISBASE"),
 "AUTHORS"), 'r')
 !         #info.SetDevelopers([unicode(''.join(authorsFile.readlines()),
 "utf-8")])
 !         info.SetDevelopers([unicode('List of authors is too long to be
 displayed here.\nUse menu Help - GRASS GIS Authors for more details',
 "utf-8")])
 !         #authorsFile.close()
           wx.AboutBox(info)
 diff patch for menudata.xml:
 $ diff -c menudata.xml patched_menudata.xml
 *** menudata.xml        Sat May 16 09:52:30 2009
 --- patched_menudata.xml        Sun May 24 02:14:54 2009
 *** 2378,2388 ****
           <help>Display the HTML man pages of GRASS</help>
           <handler>self.RunMenuCmd</handler>
           <command>g.manual wxGUI</command>
 !       </menuitem>
 !       <menuitem>
 !         <label>About GRASS GIS</label>
 !         <help>About GRASS GIS</help>
 !         <handler>self.OnAboutGRASS</handler>
         </menuitem>
         </items>
       </menu>
 --- 2378,2398 ----
 !       </menuitem>
 !       <menuitem>
 !       </menuitem>
 !       <menuitem>
 !         <label>GRASS GIS License</label>
 !         <help>GRASS GIS License</help>
 !         <handler>self.OnGRASSLicense</handler>
 !       </menuitem>
 !       <menuitem>
 !         <label>GRASS GIS Authors</label>
 !         <help>List of GRASS GIS Authors</help>
 !         <handler>self.OnGRASSAuthors</handler>
         </menuitem>
         </items>
       </menu>
 i'm attaching both files just in case ...
Ticket URL: <http://trac.osgeo.org/grass/ticket/588#comment:1>
