[GRASS-dev] Re: [GRASS GIS] #598: MacOS X / OpenGL and Wxpython
	incompatible
    trac at osgeo.org
    Mon May 25 11:51:15 EDT 2009
#598: MacOS X / OpenGL and Wxpython incompatible
  Reporter:  vince   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  6.4.0
 Component:  NVIZ    |     Version:  svn-trunk
Resolution:          |    Keywords:
  Platform:  MacOSX  |         Cpu:  OSX/Intel
Comment (by cmbarton):
 Replying to [comment:19 vince]:
 > Replying to [comment:18 kyngchaos]:
 > > OK, I figured out autoconf, and patched configure and a few makefiles
 in dev6 branch r37402 so that a 64bit build will work with a 32bit Tcl/Tk
 Aqua.  Try it out.  I'll port it to release 6.4 and trunk if there are no
 problems with compilation.
 > Great. Was off in vacation, will do that tomorrow.
 > Thanks, I'll keep you posted
 I compiled GRASS 6.5 on the Mac OSX 10.5.7, 64bit last night. After the
 last fix yesterday, it went fine and compiled with no errors.
 Everything seems to run OK. I've loaded and viewed maps with the wxPython
 GUI, viewed a raster DEM in the wxPython 3D view, and loaded maps in TclTk
 NVIZ. I'm using TclTk 8.5 aqua from ActiveStates.
 Unless there is another specific module that I should test, this seems
 ready for backport. Thanks to all of you who made this work.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/598#comment:20>
