#598: MacOS X / OpenGL and Wxpython incompatible
Reporter: vince | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: NVIZ | Version: svn-trunk
Resolution: | Keywords:
Platform: MacOSX | Cpu: OSX/Intel
Comment (by cmbarton):
I know what the problem is here, but am not sure how to fix it on your
system.
If you compile vdigit for wxPython, it also creates a local, swig version
of PseudoDC and sets a flag so that wxPython uses this local version
instead of the generic one. If something goes wrong with your vdigit
compiling, this local PsuedoDC is not made, but wxPython still tries to
use it. The result is that your display system is non-functional.
Hopefully, this helps you troubleshoot a bit. Martin might have more
insight into this.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/598#comment:22>
