[GRASS-dev] Re: swig/python setup.py removed?
William Kyngesburye woklist at kyngchaos.com
Mon May 25 16:55:06 EDT 2009
OK.
Is swig even built in a default configuration?  It's not in the list
of SUBDIRS in the main makefile.
If I cd to swig/python and make, I eventually get an error in
proj_wrap because the PROJ include dir is missing from the compile
flags, then after adding PROJINC, later in vector_wrap the GEOS
include dir (GEOSCFLAGS).
On May 25, 2009, at 2:55 PM, Martin Landa wrote:
> Hi,
> 2009/5/25 William Kyngesburye <woklist at kyngchaos.com>:
>> Martin, just wondering why swig/python was changed to use the
>> makefile only
>> instead of setup.py?  Now we're back to the same problem we had
>> with the wx
> they hasn't been used at all. To avoid mess I removed them. Feel free
> to update them and put them back.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
