[GRASS-dev] g.setproj from XY locn?
Mon May 25 17:56:01 EDT 2009
Hamish wrote:
> g.setproj doesn't let you run it from a XY location.
> is that really necessary? it makes it hard to import unprojected imagery,
> reset to known bounds with r.region, and then change into a lat/lon
> location. note in that workflow the raster's cellhd/ file must be hacked
> to be proj: 3.
You could probably merge the "case 0" with PROJECTION_OTHER, so it
prompts for the projection.
