[GRASS-dev] Re: [GRASS GIS] #618: rfe: r.md5sum or equivalent
GRASS GIS trac at osgeo.org
Thu May 28 09:33:08 EDT 2009
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.5.0
 Component:  Raster       |     Version:  svn-trunk
Resolution:               |    Keywords:  testsuite, r.univar, md5sum
  Platform:  All          |         Cpu:  All
Old description:
> Hi,
> It would be helpful for comparing maps if there was some r.md5sum or
> equivalent.
> Actually I think a new flag for r.univar might be all that is needed.
> presently this is what we got, and it's a bit less than optimal,
> especially for quickly running through a test suite
> r.mapcalc diff=map1-map2
> r.univar diff
> g.remove diff
> thanks,
> Hamish
New description:
 It would be helpful for comparing maps if there was some r.md5sum module
 or equivalent.
 especially for quickly running through a test suite:
 r.univar diff
 g.remove diff
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/618#comment:1>
