[GRASS-dev] Re: [GRASS GIS] #618: rfe: r.md5sum or equivalent
GRASS GIS trac at osgeo.org
Thu May 28 19:11:24 EDT 2009
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.5.0
 Component:  Raster       |     Version:  svn-trunk
Resolution:               |    Keywords:  testsuite, r.univar, md5sum
  Platform:  All          |         Cpu:  All
Comment (by glynn):
 Replying to [ticket:618 hamish]:
 > It would be helpful for comparing maps if there was some r.md5sum module
 or equivalent.
 What '''exactly''' should this module compute? MD5 and other hash
 algorithms operate on a sequence of bytes, so you need to decide exactly
 how to serialise the data.
 Should it operate upon the raw map data, or after reclassing, MASKing, and
 clipping and resampling according to the current region? How are nulls
 represented? Are numeric values serialised big-endian, little-endian, or
 in the host's native format? Or as decimal values in ASCII?
Ticket URL: <https://trac.osgeo.org/grass/ticket/618#comment:3>
