[GRASS-dev] Re: [GRASS-user] Access mapsets out of grass (small problem when launching a grass session)
Maris Nartiss maris.gis at gmail.com
Tue Nov 3 04:11:05 EST 2009
I apologise to everyone affected by my bad code. As of r39670 Ctrl+C
should not anymore quit GRASS session.
Maris.
2009/11/3, Glynn Clements <glynn at gclements.plus.com>:
> [CC to grass-dev]
> Νίκος  	Αλεξανδρής wrote:
>> However, I have a small problem: sometimes I launch grass6_dev or
>> grass_trunk (my default is grass64) and whenever I hit Ctrl+C to break a
>> running process, it happens sometimes to hit it twice and this breaks
>> also the grass(6_dev or _trunk) session to break.
> This appears to have been introduced in:
> 	http://trac.osgeo.org/grass/changeset/39350#file3
> It doesn't appear to be in 7.0, though; if you're seeing it there, I
> don't know what's causing it.
> The change is a mistake, and should be reverted or modified.
> The motivation appears to have been to allow the GUI to kill the
> shell; in which case, it should have used some other signal (e.g.
> SIGTERM, SIGHUP, SIGQUIT).
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
