[GRASS-dev] Re: [GRASS GIS] #799: Add -o option to muliple import
of GDAL data
trac at osgeo.org
Tue Nov 3 07:17:53 EST 2009
#799: Add -o option to muliple import of GDAL data
Reporter: trochtaj | Owner: martinl
Type: enhancement | Status: assigned
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords: import, multi
Platform: Unspecified | Cpu: Unspecified
Comment (by martinl):
Replying to [comment:7 mmetz]:
> > > Just for clarification, the -o flag means "Override dataset
projection (use location's projection)", same like in r.in.gdal. Thus your
suggestion to set -o as default means override dataset projection by
default?
> > No, I am not speaking about CLI, but just about wxGUI dialog for
multi-import (gdialogs.py).
> > Anyway I would to suggest to add '-o' to v.external (to be consistent
with r.external).
I would keep this behaviour for GRASS 6.4. In GRASS >= 6.5 there are
options and user can decide if to override check or not.
> Hmm, I think this is somewhat a matter of taste, but IMHO overriding the
dataset projection by default may be a bit dangerous. Having that option
for v.external would be a good idea.
> > > The new wxGUI dialog is not consistent with regard to OGR layers and
OGR datasources, for e.g. *.gpx and *.kml files, datasources are listed as
layers, although these datasources hold layers themselves. With so many
different supported OGR formats, I would strongly opt to at least stick to
the terminology used by OGR in regard to what is a datasource and what is
a layer to avoid user confusion.
> > Right, I am just not getting point in which ways is wxGUI dialog
wrong.
> File -> Import vector map -> Multiple vector data import using OGR
> There it reads "List of OGR layers", below that "Layer" and "Layer
name". What is listed there can just as well be OGR datasources not
layers, and within these OGR datasources are layers not listed in the
wxGUI dialog. It seems that this dialog is written for shapefiles, not
sure how to use that with e.g. kml, gpx, postgresql if the idea is to have
a separate output vector map for each layer.
Right, dialog was written for shp/tiff/dxf. Should be improved at least in
GRASS 7. I would suggest to close this ticket as worksforme for 6.4.0.
Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/799#comment:8>
