[GRASS-dev] fix for build, ERROR: MAPSET PERMANENT - permission denied
Thu Nov 5 07:00:09 EST 2009
Raymond Burns wrote:
> I was looking for something else when I noticed this.
> There are embedded tabs present so the attached properly formated
> patch is the proper way to apply (do not cut and paste)
> diff  include/Make/Html.make.orig include/Make/Html.make
> 85c85,86
> < htmldesc = \
> > htmldesc:
> >       htmldesc = \
> This causes make to perform correctly but I do not know if the
> output is as intended, I believe it now functions
What problem is this supposed to fix?
Also, I can't see how the patched version can work, as nothing tries
to make the "htmldesc" target.
