[GRASS-dev] Re: [GRASS GIS] #76: Calculation of bearing between 2 points, using d.measure
GRASS GIS trac at osgeo.org
Tue Nov 10 07:53:17 EST 2009
  Reporter:  dylan        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  6.5.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:  d.measure
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:6 martinl]:
 > What about m.measure in GRASS 7? This module could read x,y coordinates
 from stdin as you suggested. The module could used by GUI.
 That possibility was why d.measure was retained.
 Whether such a module should be called m.measure (or g.measure) or
 d.measure depends upon whether the coordinates are cartographic
 coordinates or display coordinates.
Ticket URL: <https://trac.osgeo.org/grass/ticket/76#comment:7>
