[GRASS-dev] Re: [GRASS GIS] #806: WinGRASS: Problem with special characters (wxpython GUI)
GRASS GIS trac at osgeo.org
Thu Nov 12 13:24:55 EST 2009
  Reporter:  marmai        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass,umlaut charcter,german
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by marmai):
 Replying to [comment:2 cnielsen]:
 > It might help if you could tell me if this is the first version of
 wingrass you have had a problem with?
 I am not sure. I used the former wingrass versions, but I realized this
 problem the first time in this version. But I am not sure that this
 problem was not there in the older versions. Is it possible to get
 somewhere the old binary installer (for the old versions), then I will
 install a older version to check for this problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:3>
